跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
iPhone that can't charge
Hello,
I am in possession of an iPhone that will not charge. When you insert the dock-cable the phone notice that it is attached to the to charger but the battery is not gaining power. I have tried to replace the old battery with a new one but this has not solved the problem. I have also restored the device to see if it was the software that was corrupted but with no result as well.
I have also thought about the possibility that it might be the dock-entrance that needed replacement but would the iPhone then register that it is attached to the charger?
Anyone who has seen this problem before? Any solutions?
Best regards,
Frederik
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
添加一条评论
3个答案
已选择的解决方案
Hi,
If by any chance your Phone is still covered by warranty, contact the vendor.
If not, then if using a known good charger, cable, battery, and replacement dock connector does not solve the issue, you probably have a fault on the logic-board.
There are a few (sets) of components on the board that, if gone bad or missing, will cause this error: no charging or fake charging (meaning the iPhone detects the charger, but does not charge).
Working on the iPhone to change the screen for example, may cause some of the components to be affected.
I suggest looking at this post for more details. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If you've replaced the battery with a confirmed good battery, then I would look at changing the dock connector.
这个答案有帮助吗?
得分 2
1条评论:
That would be the next step, I try that. But I just think it is weird that the phone can detect that the cable is in the phone but won't charge.
完成的
添加一条评论
The dock connector is the problem check the pins on it and clean it. if there is pins missing it could register the charger but it can't provide a charge because that pins is missing or so forth. My bet is you might have to replace the dock connector if the battery is a confirmed good battery and the charger is a confirmed good charger it has to be the dock connector if its missing pins it can see the charger but not get a charge.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Frederik Novak Jansen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 593
