跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
broken power button on my iPod Touch
I need the power button on my iPod Touch 1st generation fixed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
I fixed it i went to ifixit.com and bought a rear panel for my 1st generation iPod Touch
thats how you fix the power button on it
完成的
good that it worked for you. i asked because sometimes the golden spring breakes away and then you can't simply change the rear panel to fix it. but as i said - glad that it workes again
完成的
man you can fix the power button with a paper clip
and you can fix the power button by buying a rear panel for the iPod.
完成的
添加一条评论
7个答案
最有帮助的答案
there is a small metal clip when you open up the ipod touch 1st generation back panel its a little golden clip next to the ribbon that connects the digitizer here is a picture:
If that Clip isn't there then thats your problem I recently had this problem I had used the metal piece from a pencil I cut it with scissors and folded it and placed it in its place and closed it up after that it worked fine.
Hope this is Helpful :)
这个答案有帮助吗?
得分 1
添加一条评论
anything happend with the iPod ?
was the iPod opened or dropped ?
or id the button itself defective ?
这个答案有帮助吗?
得分 0
1条评论:
it was dropped
完成的
添加一条评论
also umm you can fix the power issue with a paper clip just move it around until you hear sparks while holding the home button
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
i have exactly the same problem, mine also was dropped and the back pannel fell off, i clicked it back on and the button was sometimes working and sometimes not, but now its stopped working all together.
这个答案有帮助吗?
得分 0
添加一条评论
where i can i buy replacement connection clips?
这个答案有帮助吗?
得分 0
添加一条评论
thanks jpinheiro1993 this worked for me. the little bugger is fidgety though so if the rest of your i pod is opened watch for that thing it will fall out if your not careful.
这个答案有帮助吗?
得分 0
添加一条评论
hahahahaha i have the exact problem the little metal part was nt there so once i heard that they fixed it with paper clips n stuff like that i got a metal needle and just placed it where the little metal part is supposed to be and wiggled it and it turned off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
elais 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 23,519
