broken power button on my iPod Touch
I need the power button on my iPod Touch 1st generation fixed
there is a small metal clip when you open up the ipod touch 1st generation back panel its a little golden clip next to the ribbon that connects the digitizer here is a picture:
If that Clip isn't there then thats your problem I recently had this problem I had used the metal piece from a pencil I cut it with scissors and folded it and placed it in its place and closed it up after that it worked fine.
Hope this is Helpful :)
这个答案有帮助吗?
anything happend with the iPod ?
was the iPod opened or dropped ?
or id the button itself defective ?
这个答案有帮助吗?
it was dropped
also umm you can fix the power issue with a paper clip just move it around until you hear sparks while holding the home button
这个答案有帮助吗?
man you can fix the power button with a paper clip
and you can fix the power button by buying a rear panel for the iPod
i have exactly the same problem, mine also was dropped and the back pannel fell off, i clicked it back on and the button was sometimes working and sometimes not, but now its stopped working all together.
这个答案有帮助吗?
thanks jpinheiro1993 this worked for me. the little bugger is fidgety though so if the rest of your i pod is opened watch for that thing it will fall out if your not careful.
这个答案有帮助吗?
hahahahaha i have the exact problem the little metal part was nt there so once i heard that they fixed it with paper clips n stuff like that i got a metal needle and just placed it where the little metal part is supposed to be and wiggled it and it turned off
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 23,518
3条评论
I fixed it i went to ifixit.com and bought a rear panel for my 1st generation iPod Touch
thats how you fix the power button on it
由 elais 完成的
good that it worked for you. i asked because sometimes the golden spring breakes away and then you can't simply change the rear panel to fix it. but as i said - glad that it workes again
由 markus weiher 完成的
and you can fix the power button by buying a rear panel for the iPod.
由 elais 完成的
