跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
I pod cannot turn on to the main menu
Why my i pod can not connect to the i tunes and now always ask update software from i tunes but can not connect to the i tunes???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
My I pod generation 5 is i pod classic 80Giga. Before I was copy songs from iPod to my computer but iwas wrong when click the mouse to be paste to my iPod again until double songs in my iPod and then I delete some songs in my i pod after thet i turn off my i pod. when I turn on my i pod now always asking for restore to the itune by connect internet. the problem is my i pod cannot read on i tunes my computer??
完成的
did you try to make a hard reset ? here is the support page: http://support.apple.com/kb/ht1320
try to reset it and after that we will go further
完成的
添加一条评论
2个答案
已选择的解决方案
What iPod generation do you have ?
anything happend in the past ? (dropped, water damage..)
try to clean the dock connector with a soft paintbrush
这个答案有帮助吗?
得分 1
2条评论:
all i get when i press menu/middle is www.apple.com/support/ipod
完成的
earl martin, is this the same iPod as described in the question or is this a separate iPod? If it is not, it would be better if you would ask your own question so that we can help you...
完成的
添加一条评论
ok this is wahat you should do. you should press menu button and middle button same time about 6 to 10 sec and wait for apple sign come show up and you can see a main menu again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
achmadzaiful 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 929
