跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Hard drive cable A1278 model 821-1226-A instead of 821-0814-A
Hi, please i would like to know if there is any speed decrease or problems if i use this hard drive cable A1278 model 821-1226-A instead of 821-0814-A.
Macbook pro mid 2012 can use an old hdd cable , but i would like a confirmation that all will be good and there is no impact on performances,read/write datas speed etc...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
Before doing this highly dubious switch, you might want to read over this question: Using new hard drive cable in older machines 821-1480-A
这个答案有帮助吗?
得分 0
1条评论:
Thank you sir , but this doesn't solve my problem,i would like to understand the role of this cable , and informations about different cable models if you have them ,thanks
完成的
添加一条评论
We have test them and have no notice in decrease performance or issues running that cable as we have had a lot of troubles with the new cables failing a lot
这个答案有帮助吗?
得分 0
1条评论:
Who is "we"?
完成的
添加一条评论
They are different lengths, although some places will sell you the same cable for these two different part numbers. 821-0814-A is longer than 821-1226-A. I advise using the correct cable as extra stress on the cable will most likely mean it doesn't last as long as the correct one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
faceofjock 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 9,282
