跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
Replaced Power Supply, Getting a Black Screen On Startup
I have an early 2006, 20' iMac. A few days ago it was completely unresponsive when I tried to start it up.
I ordered a new power supply and replaced it today.
With the new power supply it started up immediately. However, right as you hear the chime the screen quickly flashes grey and then goes black.
The computer continues to boot however, and I know that it's running....after clicking around the black screen for a while I was able to find iTunes and start it playing music.
I tried multiple SMC and PRAM resets, and when that didn't work I opened it back up and reseated all of the LCD connections.
None of that worked though.
What's very odd is I pressed the power button to put it to sleep, and then when I wake it up, my desktop flashes across the screen for maybe a second or two.
So that must mean there is some kind of connection, and the LCD can't be completely shot, right?
Are there any other options I can try to get it working?
EDIT: Also want to mention it's not the backlight, when I say the screen is black I mean as if the computer were on standby or shut down.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
to hook it up you need a working OS. What if you have no OS and are trying to install one?
完成的
添加一条评论
1个答案
Hook it up to an external monitor and see if it works. If it does, I'd replace the inverter. Here's how: iMac Intel 20" EMC 2105 and 2118 Inverter Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 203
