跳转到主内容
加入维修社区 - 创建账户
3 Long Warning Beeps
Hello all, today I heard, for the 1st time, a sequence of 3 long beeps from my MacBook Air 11' mid 2011. It was in sleep mode but felt extremely hot. Also I noticed that the battery had gone from 96% when I put it to sleep to 65% in the 15 minutes that it was asleep! When I opened it up it didn't start, pressed the power button for 5-6 seconds and thankfully it powered up and I was taken to the login screen. Have been using it now for last hour and battery use is normal.
After some frantic googling it seems that the 3 beeps are a warning for bad ram? Is it possible to swap out the ram? Would be confident enough of opening up my beloved, have previously used ifixit for iPhone 3G & 4 parts/guides so hopefully this can be done!
thnaks for taking the time to read my question :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
The RAM on your machine is "onboard", that is built into the logic board. It cannot be changed or upgraded after purchase. I would keep a everyday Time Machine hard drive (SSD) backup. Your machine could last a long time or it could fail in the next 5 minutes. "Therefore keep watch, because you do not know the day or the hour."
这个答案有帮助吗?
得分 2
1条评论:
thanks for the quick reply :)
完成的
添加一条评论
添加你的答案
collinsmikep 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 866
