跳转到主内容
针对近期推出的Mac笔记本电脑以及台式机的完全拆卸和组装指南。
42835 个问题 查看全部
Security Code lockout with 10.9 upgrade
I had a customer come in with a 21.5" iMac Mid 2010. She had bought it on Craigslist with no hard drive in it. I formatted a new 1 TB hard drive and set it up for 10.6.8 and and cloned a system externally. Then dropped it in and all's well. The machine runs great.
She got home and tried to upgrade to Mavericks. It asked her for the security code which she did not have. She brought it back to me. When trying to start all I can get to is a screen asking for the code both on regular boot and "R" boot.
I reformatted the drive externally and put 10.6.3 back on it. Now when I try to boot I get a padlock symbol. Looks like Mavericks activates a request for a passcode and then locks up in the EFI firmware chip. This really worries me about buying any logic boards or older Macs on eBay. How can I tell if a passcode has been used? How can I get rid of it? Do I have to reprogram the chip? Do I buy a pre-programed one on eBay and solder it in, if so do I need a soldering work station or will a heat gun work? This issue could potentially be devastating. Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi mayer,
I had the same problem and fixed it removing one of the RAM modules, then resetting the PRAM by holding the option, alt P and R key while starting up (three chimes did the trick). After that I installed the RAM module I removed and it did not ask for the password again.
Hope this helps!
Nathan
这个答案有帮助吗?
得分 1
1条评论:
Sometimes I need a jump start to my brain working.. this worked just fine. Thanks so much.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 188
