跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 个问题 查看全部
Is Replacement Glass possible for iMac Intel 21.5" EMC 2638?
I have recently scratched my iMac 21.5" glass screen.
Is there a way to replace the Glass screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
5条评论
Apple iMac "Core i5" 2.7 21.5-Inch (Late 2013) Specs
Identifiers: Late 2013 - ME086LL/A - iMac14,1 - A1418 - 2638
完成的
Need the glass too, that link doesn't work. Please help, I can't find it! Thanks...
完成的
Can someone please help to locate a replacement LCD and glass.
That link is expired.
完成的
john doe - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer, Question or create your own original Question. READ THE UPDATE to the O.Q.
完成的
I am wainting for this answer, please write me if you know something new
完成的
添加一条评论
4个答案
最有帮助的答案
Took it apart... It's literally glued to the screen glass. Apple removed the original glass from the LED monitor and fused it to their glass. You cannot replace just the glass.
这个答案有帮助吗?
得分 3
2条评论:
I was able to successfully remove just glass cause I cracked it just a little but turns out you can’t even buy just the glass alone for this model you can only buy glass only for previous models. So even if you do remove this glass there’s no other option that to replace lcd as well. It’s similar to fixing iPhone screen glass only and peeling slowly from loca glue.
完成的
Yeah, I didn't even get close to separating the screen and the glass. Instant breakage. I wish I could find a %#*@ screen for this thing... ^*&^&)*^*(&)*
完成的
添加一条评论
Here's how to take it apart: https://www.youtube.com/watch?v=5jyMvGZD...
Here's the glass: http://www.alibaba.com/product-detail/Wh...
这个答案有帮助吗?
得分 0
添加一条评论
Here's where I got mine. I had originally bought the glass, hoping to remount it to the LCD. No such luck, it's fused and would require tools and experience I didn't have.
Ebay.com
Seller: om.technology ( 103 )
Item title Price
Shipping price
Qty Item total
Original New iMac 21.5" LCD Screen LG LM215WF3(SD)(D1) ( item: 231212481637 transaction: 1028623781013 )
Paid on May-16-14 $268.00 $52.00 1 $268.00
Expedited Shipping from outside US
Estimated delivery: Tue. May. 20 - Fri. May. 23
Subtotal $268.00
Shipping and handling $52.00
Total $320.00
这个答案有帮助吗?
得分 0
添加一条评论
http://www.ebay.com/itm/Full-LCD-Screen-...
This one will much?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sol 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 27,835
