跳转到主内容
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 个问题 查看全部
How do I replace the back light in the Delco CD-Radio unit?
The back light of the LCD display has burned-out. Otherwise the radio works fine.
1) How do I remove the radio without marking-up the console?
2) Where can I find a replacement back light?
3) Do I have to take the car to a GM dealer to power-up the fixed radio?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
There is a forum for Pontiac Grand Ams (www.gaownersclub.com/forum) which may have some helpful how-to articles.
As for replacing the back light, you might be able to find an entire factory radio replacement on Ebay or at a site like sonicelectronix.com that sells factory stereos. It's probably not cost or time efficient to try to just replace the back light. A new after-market stereo might also be cheaper.
这个答案有帮助吗?
得分 0
添加一条评论
Take the radio out. Follow a Repair guide, you can get one at a auto parts store. Once Radio is out take the face plate off. Then remove the screws that hold the circuit board on. Then you will need to desolder the bulbs they will be small 3mm bulbs looking like LED's. You will need to get 12 Volt to replace them with. I got mine at a electronics supply shop. You ant to get something that looks kinda like this. 12V 35mA Micro Lamp
这个答案有帮助吗?
得分 0
添加一条评论
There is a simple twist in bulb for the backlight: ACDelco 16208443 GM Original Equipment Multi-Purpose Light Bulb, I found mine on Amazon, you can get them at most GM dealers for a buck or 2 more if you don't want to wait.
The trim around the radio just pops off, held in by a few clips, a small flat blade screwdriver slipped between the trim and the dash will lift it enough to get a grip with your fingers, then just pull gently, the trim ring around the ignition will also pop off, separate piece.
Once the trim is off, there are 3-4 screws holding the radio unit in, remove them and slide the radio forward enough to reach behind and undo 2 wire connectors and the antenna cable.
The faceplate is held on by a few plastic clips that snap onto the radio chassis, gently pry these up with your small screwdriver and the faceplate should come free with the small circuit board holding the build attached, twist out, twist in the new one and reassemble. Took me about 15-20 minutes total.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Merv Doda 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 12
总计 8,186
