跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2619 个问题 查看全部
iTouch stopped working after being dropped in cereal
My son dropped his iPod Touch into his cereal bowl this morning, milk and all. It stopped working as a result.
My current plan is to give it time to dry out and then see if it will start back up.
Is there anything I should/could do prior to trying to start it back up?
Also, if it doesn't start back up, is there anything else I can do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
your idea to let it dry out first is a good one, it may take time to dry out thoroughly
there's another almost identical question from about an hour ago, rather than repeat what was said perhaps take a look over here:
How do I fix a wet iPod?
good luck
这个答案有帮助吗?
得分 3
1条评论:
Thanks! I'll give it a shot.
完成的
添加一条评论
Liquid damage is a killer for electronics. First thing is to turn off the iPod and remove it from it's power source. Hopefully this will prevent the logic board from getting shorted out. Next, I recommend taking the iPod apart following our guide and letting it dry out for a few days. While the iPod is apart and drying out, you can use some rubbing alcohol and q-tips to try and clean any milk residue you see. The rubbing alcohol evaporates quickly and will not damage the iPod further. Finally, put the iPod back together, cross your fingers, and hope it works.
If that does not fix the problem, then you probably, at minimum, need to replace the logic board. Hope that helps you.
这个答案有帮助吗?
得分 2
1条评论:
Thanks! I'll try drying it out, following the guide.
完成的
添加一条评论
i had same problem with a pool though and yea i just let it dry out and it works for the most part fine now
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
carlweir 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 4,991
