跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
No right channel in headphone jack
The right channel is out on my headphone jack. Tried several headphones so I know it is the jack itself. If I squeeze the phone where the jack is, the channel temporarily comes back. I took the phone to the apple store and they couldn't find a simple fix.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Then
you'd have to replace the headphone jack, maybe the logic board is damaged.
这个答案有帮助吗?
得分 0
1条评论:
Like machead3 said, the easiest way to isolate the logicboard is a new headphone jack assembly
If you still have issues, I would go ahead and suggest a bad logicboard
完成的
添加一条评论
添加你的答案
ton y 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,198
