跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2397 个问题 查看全部
问题已关闭
What to replace in non-vibrating iPhone
My iphone 4 stopped vibrating two weeks after I got my phone. I've had then phone now for a year and a half and want to fix it so that my phone will vibrate again. What replacement parts do I need to order and learn how to replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi there it can be 1 or two things
It's either the motor has burnt out or it's the actual headphone, silent or volume flex.
Before you order any parts you could just take out the motor and bend the little prongs slightly and see does this sort it
iPhone 4 Vibrator Replacement
iPhone 4 Vibrate Ring Switch Replacement
iPhone 4 Vibrator图片
指南
难度:
中等
20 - 40 minutes
iPhone 4 Vibrate Ring Switch图片
指南
难度:
困难
这个答案有帮助吗?
得分 1
添加一条评论
Also, the 4 GSM and the iPhone 4 verizon use different vibrators. the Verizon/CDMA version uses a button shaped vibrator, like in the 4s.
iPhone 4 Verizon Vibrator Replacement
make sure you buy the correct part, if you need to take that path.
iPhone 4 Vibrator图片
指南
难度:
中等
20 - 40 minutes
iPhone 4 Verizon Vibrator图片
指南
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 65
