Why does my iPod show a folder with a warning sign?
My iPod shows a folder with a warning sign and below it the words www.apple.com/support/iPod. What could the problem be and how can it be fixed?
normally that would mean that the hard drive of the iPod needs to be replaced - any clicking sounds in the past ?
这个答案有帮助吗?
please click here - expecially the posting that is shown first (you should read the rest too - but this one could be important
since the link i wanted to add is a little bit censored, i can only recommend you a googe search with: "iPod diagnostic mode" <- use it incl. the " - the first result should give you some informations about the diagnostic mode and how to verify your harddrive without the use of a computer
good answer +
Go to www.apple.com/support/iPod like it says.
There are several different warning signs that Apple uses. Please take a look at this link: http://support.apple.com/kb/HT1378
to identify which one you have and the probable fix.
这个答案有帮助吗?
fresh research +
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 26
总计 2,888
