跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
问题已关闭
iMac 27" Late 2012 HDD replacement to SSD
Hello,
I have iMac 27" Late 2012 MD095LL/A A1419 (EMC . It has 1TB HDD. I want to open it up to replace the HDD. I have another Macbook Pro Late 2006 2.33 GHz 2GB RAM and replaced its HDD with SSD and it's running much faster than my 2012 iMac 27" with 8GB RAM, but 1TB HDD.
So I want to ask two questions:
1) Can I do it in a way that I leave my current 1TB HDD inside and add another 256GB SSD, so I can have both together? I mean are there the required connectors / space inside?
2) If above not possible, then I will just replace 1TB HDD with 256GB SSD. Would I require to purchase some special dock for SSD to place it properly?
Thank you very much in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
it can be done but it's not easy
I suggest you see the Guide there's no caddy or dock for the SSD the chip fits into the slot and a screw on the end secures it in place..
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 2
2条评论:
I have actually seen the ifixit guide for SSD replacement, where iMac already has SSD installed. I am more interested if I can run HDD and SSD together, if currently my iMac only shipped with 1TB HDD. Or if it is not possible, how to replace HDD with SSD.
完成的
I can't think of any reason why this wouldn't work… I don't know if it could become a DIY Fusion drive… you could designate the SSD as your boot volume keep the data on the HD.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 14,712
