跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
问题已关闭
How to tell the difference between the old and the new battery?
I received a new battery and a new back case in the mail from ifixit.com and swapped out the old battery with the new one and replaced the back case without a problem. However, as I had to take out the battery several times to reseat it correctly, I may have grabbed the old one and re-installed it in error. I checked the charge on both and one is 55% the other is 62%.
I want to be certain that I did not reinstall the old battery back into the phone in error. Is there a way to tell the old battery from the new one?
The battery I presently have installed has a date ?/?/2017; the one that I took out and have on the table has no date.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The older battery might have sticky adhesive stuck to the bottom.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 1,100
