跳转到主内容
加入维修社区 - 创建账户
发布于 2000 年 7 月 19 日,型号为 M2454 的 15 英寸 Apple Studio Display 显示器。
How to tighten stand on display
I recently replaced the hinge on my display. Now the stand is loose and will not allow the monitor to be a different angles. I can not find a manual anywhere.
Thanks.
Rosemary
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Check out my link here. Ralph
http://docs.google.com/viewer?a=v&q=cach...
这个答案有帮助吗?
得分 1
2条评论:
nice link +
由完成的 分享
Looks like this link is dead. I too would appreciate any insight into a replacement hinge / mounting plate / bracket.
由完成的 分享
添加一条评论
Where did you find the hinge? I need to replace mine.
这个答案有帮助吗?
得分 0
添加一条评论
A friend gave me the 20" version of this monitor over the summer with the same issue. I thought I could find a replacement hinge on ebay or other secondary market. No luck. They were either for the wrong size or too expensive.
I had the thought of putting it in a fixed position by tapping it with a screw, but it is not made like that. Where I thought I could tap is only plastic. No luck, but a thought. Reverse it.
I turned the hinge around. You need to slide the ferrite filter to the other side. There are three index marks that will need to be filed down. Screw it back down and replace the cover and stand.
It now seats on my desk at little greater than 90°s, no slide. Gravity should keep it from coming forward.
Ok, I could have tried to set it as it was by tightening the nuts on the ends of the hinge. But I could have over tightened (not mentioned in the manual) and snapped them off and/or it might still be loose.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rosemary 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 30
总计 2,982
