How do I put a lock on my wifi router
I have a Linksys router. all my neighbors steal my wifi. how do I install a locked password
Set the encryption to WPA2 AES, nobody can hack that.
这个答案有帮助吗?
how to prevent luck so that no one can huck
i think you just need to reset the router and type 192.168.1.1 and follow the recommended settings and make your own username (SSID) and password and save the settings and restart trhe router more steps and help visit www.linksys.com/support_password.html and i hope this will help to solve the problem and let me know if you have any other question
这个答案有帮助吗?
Login to the router by accessing the webpage myrouter.local or default IP address 192.168.1.1. Now you can change username and password of the router.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 8,550
3条评论
Enable Network Encryption. In order to prevent other computers in the area from using your internet connection, you need to encrypt your wireless signals. There are several encryption methods for wireless settings, including WEP, WPA (WPA-Personal), and WPA2 (Wi-Fi Protected Access version 2)
由 Lore 完成的
i had the same issue its just reset the router and reset with recommended settings visit http://goo.gl/uglBKa . this will help you . thanks and gud luck
由 leeschelsea 完成的
thanks it was helpful
由 Ethan Logan 完成的
