跳转到主内容
加入维修社区 - 创建账户
iMac wont boot up, just the apple screen shows. Can anyone help?
My iMac turns on and has the apple screen on with the boot up continually running. There is a little circle thing that indicates that it is trying to boot up. But nothing is happening. CAN ANYONE HELP ME???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
much worse is relative - it's always bad when something like that happens
but i would do pretty much the same
- reset the iMac like this and that
if the iMac still won't boot
- use the instllerdisk and try to boot up. use the disk utility to check/repair permissions
a few more infos are here
这个答案有帮助吗?
得分 2
2条评论:
great answer if the asker knows that those colored words are links to solutions. Also how to start up from the installer disk.
完成的
you're right richard - i didn't think about that. but here we go: you have to press and hold the C key your keyboard to start from the installer disk
完成的
添加一条评论
添加你的答案
melisag247 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 25
总计 3,013
