跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
99 个问题 查看全部
Need a good source for taking apart a 23" HD Cinema display
Does anyone have a good source (an Apple service manual would be ideal) of instructions for taking apart a 23" Apple HD Cinema Display (Aluminum)? I've poked around online but haven't found anything great. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
I have the Cinema Display take apart. Email me at fedguy2@ pacbell .net
完成的
添加一条评论
8个答案
已选择的解决方案
Try this link. Ralph
http://docs.google.com/viewer?a=v&q=cach...
这个答案有帮助吗?
得分 3
8条评论:
Oh my. Any bets on how long that stays online before Apple's legal team has their way with it?
完成的
I don't think so (or they aren't able to properly use a search engine).
oh, somewhere between the n and the t is one of the search results ;-)
完成的
On the basis of Kyles remarks the OP should download this material now. Ralph
完成的
can you reup please?
完成的
Try this: service
完成的
显示更多的3条评论
添加一条评论
Once inside, check the VR3 3.3VDC REGULATOR center pin to make sure it is putting out 3.3v, bad one will put out about 4vdc. It is very common problem with this 23" aluminum case.
See my pictures here:
http://s807.photobucket.com/albums/yy352...
这个答案有帮助吗?
得分 3
1条评论:
Hi
I have a blank screen (No Lights or display) I have followed your advice and tested the VR3 Regulator. Center pin is 1.96 DCV and Right pin 5.1. Assuming this show that it is faulty I was wondering the part number i should order and maybe where you were able to source it.
Also being surface mount is there any issues with DIY or would it be worthwhile finding a new board.
Thanks in advance
完成的
添加一条评论
i've found a korean website - but the main focus is "looking inside" and not the "show others how to do it": CLICK
and a disassembling "guide" for the 20" CLICK
这个答案有帮助吗?
得分 2
1条评论:
The first link is for an acrylic monitor but the one at the bottom is what I need. Thanks.
完成的
添加一条评论
I have the 23 dvi version if you need another manual let me know.
Apple Cinema Display 23" HD DVI Manual
这个答案有帮助吗?
得分 1
1条评论:
Thank you for the link and pdf!
完成的
添加一条评论
All manuals.
http://tim.id.au/laptops/apple/
这个答案有帮助吗?
得分 1
添加一条评论
lokk at this master from Cile he helped me sure //// A1097 Broken Power Adaper fix for a 23" Apple Cinema HD Display. copy and look at Youtube good lycka
这个答案有帮助吗?
得分 0
添加一条评论
Does anyone still have this display service source pdf around? I need to take mine apart and can't find the service manual anywhere...
这个答案有帮助吗?
得分 0
添加一条评论
Add me to the list of people needing a dissassembly guide. My new-to-me display has mould on the inside of the screen :( Heartbreaking.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jasonnrogers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 35,970
