跳转到主内容
Released in 2006, identified by model number PP20L for e1505
16 个问题 查看全部
问题已关闭
Failed to unsolder the power jack. Advice for next time
I attempted to replace the power jack on a Inspiron 6400 laptop. Unfortunately I could not get any of the solder points to unsolder. I am inexperienced at unsoldering but have done it in the past and after being unable to get these to unsolder I took apart an old router and cleaned everything off the board to prove my tools were working. So. On the inspiron power jack nothing would flow into the desolder pump, I could see the solder melt but it was like I only melted the top layer and I wasn't able to get anything to suck through the board. These solder joints were small and I assume I have toasted the board from screwing with it for so long. I tried several different irons all the way up to a massive weller gun. I also tried the radio shack soldering iron with the suck bulb integrated into the iron. My desoldering pump is inexpensive but worked great deconstructing the dlink. Any idea what the difference was here in the board or my choice of tools or technique that caused me to not get this to work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Different solder can cause this. I suggest a desoldering wick and some flux. Dip the desoldering wick into flux and then desolder as usual.
完成的
添加一条评论
1个答案
已选择的解决方案
Some solder has a higher melting point and can be quite difficult to remove in comparison to weaker solder that seemingly melts on touch. I personally pre-heat the area with a rework station then heat the solder and use a sucker and desoldering braid to clean up the board and remove leftover layers. I'd have to see a photo of the board to tell if it's toasted, maybe not. I accidentally overheated and warped/damaged a motherboard around the power jack and it still worked because the traces were ok, so there's a chance!
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 525
