跳转到主内容
型号A1040 / 10, 15, 20, 30, 或 40 GB 硬盘/ 中央转盘上方有四个触控激活 LED 背光按键
97 个问题 查看全部
Replaced hard drive, restore fails with error 1429
My iPod 3g (iPod with Dock Connector) died many years ago due to a failed hard drive. I have recently replaced the HD, but now it won't restore. iTunes gives error 1429 after it attempts to do so. Trying to format the drive via Disk Utility merely results in it hanging indefinitely at "Partitioning."
What could be causing this? The iPod passes all internal diagnostics, including the hard drive surface scan. The Mac sees the iPod, and even (once) mounted the drive on the desktop.
Something else I've noticed that may or may not be related: When the iPod is plugged in (via FireWire), my Mac tends to hang. Operations such as restarting or closing iTunes will take a very long time. This was true even before it died and on a different Mac. I always chalked it up to FireWire, but perhaps it's some sort of clue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Jim Syler, the first thing I'd try is what Apple suggest on here. If that does not help at all, try to reformat the drive with NTFS file system (Windows) and then switch it back to your OS. The restore option in iTunes should then restore your iPod back to factory settings using Mac. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
It turns out that this is a FireWire issue. Either it's my FireWire cable or it's some problem with FireWire in general with this iPod. Reformatting the drive using Disk Utility to FAT and restoring it via USB on a Windows computer worked perfectly, and now it works fine on my Mac via USB, but will not even mount via FireWire, though the iPod recognizes that it's plugged in and the computer gives an error when I unplug it.
完成的
添加一条评论
添加你的答案
Calion 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 2,746
