跳转到主内容
Generally referred to as pants. Repairs range from patching a hole to replacing a zipper.
How do I sew a merino wool base layer?
I have a pair of well worn merino wool base layer bottoms that I am looking to repair. I want to know the correct way to sew this particular knit so that I can fix them without ruining the integrity of the bottoms. Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I wrote a step by step instruction guide to show you how to repair a hole in your merino wool underwear. This guide assumes that you know how to thread a needle and have, at the very least, some basic sewing skills.
This repair is specifically for the crotch of a pair of Icebreaker Beast underwear. This guide should help you repair any Icebreaker, Smartwool, or ExOfficio underwear; or any other merino wool gear.
http://www.hcrbeta.com/how-to-repair-a-h...
这个答案有帮助吗?
得分 3
3条评论:
Thanks Jason - SPOT ON. New LIFE to all my outdoor winter gear.
完成的
Jason...I need to shorten the sleeves of a SmartWool sweater. Do you know if I can do that, or should it be a professional project? Thanks,
完成的
You can shorten the sleeves two ways. One you can hem the end of the sweater by folding it in and using a catch stitch. Or. You can fold out a certain amount on the inside and sew the two ends of the fold together. Be sure the fold is equal all the way around. The fold won't be noticable if is taken where the ribbing ends and other kind of stitching begins.
完成的
添加一条评论
最有帮助的答案
You don't sew it, you darn it. Here's how: http://www.ehow.com/how_8790736_darn-woo...
这个答案有帮助吗?
得分 3
添加一条评论
I use wool felting to repair my wool socks and merino underwear. Works really well.
这个答案有帮助吗?
得分 0
1条评论:
How exactly do you do that? Do you just sew a patch of the felt over the area?
完成的
添加一条评论
添加你的答案
Hereks 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 49
总计 19,730
