跳转到主内容
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
Why my camera is not working?
camera problems
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
I have the same problem as well as not being able to open files. The main answer is that the device is not recognizing the memory card. I can't figure out why. When the tablet starts up, it recognizes the card. The load card option does not work. The card itself has been wiped clean and the tablet says so. I did not wipe it clean. I've removed and reinserted the card. Turned the tablet off and on. Nothing works. I last remember being able to use the camera as well as open pdf and other files before a virus software update.
完成的
添加一条评论
3个答案
Maybe you have 2 much stuff on tablet try freeing up some space hope you fix your camera
这个答案有帮助吗?
得分 0
添加一条评论
Does your phone dropped before? How long have you used it?
这个答案有帮助吗?
得分 0
添加一条评论
how to set the back camera
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
NIGELLE Pedrosa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,880
