跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Fussion drive - connectors?
I wonder if I buy iMac 27"late 2013, with fussion drive, and eventualy want to change it, is there also pcie connector for SSD, and SATA connector like on other, non fussion drive, models?
Also, I wonder how fussion drive is connected? PCIe, or SATA, or both? And if that SSD part in fussion drive works on same speed as regular SSD PCIe drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Apple's Fusion Drive is a not a special drive. It's the software bonding of two drives: a standard SATA HD, and a SSD, so the two devices are seen as a single drive.
Depending on what system you are working with you could use a standard SATA SSD or might need a Apple proprietary SSD unit. In this case you have a Apple proprietary SSD unit and a standard SATA HD drive to create your Fusion Drive.
OK, now some newer Thin models don't have the logic board fitted with the needed PCIe parts to connect the SSD. So be careful on what you are buying. The Late '13 has the connector parts, but the late '12 and a few early '13 model's did not.
Check EveryMac with your serial number to verify.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Milan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 378
