跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1230 个问题 查看全部
Can we change the rear plastic iPhone 5c?
Hello. I'm French, so sorry for my English. I wanted to know if it is possible to change the back cover of the rather colorful plastic iPhone 5c. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
1条评论
Couldn't you get in some legal troubles for buying a back housing containing the apple logo? Last I read (on some random forum), someone's $xxxx shipment of iPhone parts was withheld in customs for this very reason (Trademark infringement).
Be careful!
完成的
添加一条评论
6个答案
已选择的解决方案
Hi, Elouen. It is possible to replace the rear case of the iPhone 5c. Just follow this guide to replace the case. You can order the rear case from the iFixit store.
这个答案有帮助吗?
得分 1
3条评论:
Can anyone confirm whether or not you need to actually removed the whole front screen and parts on the inside to change the back... I've watched some videos that basically do that, but just want to make sure
完成的
will it afftect the use of the phone?
完成的
If you do decide to change it would it deleate or rest the phone memory ?
完成的
添加一条评论
最有帮助的答案
It is possible, however it may be hard to find the part.
这个答案有帮助吗?
得分 1
添加一条评论
Hello. You can replace a new iPhone 5c back cover that is not a hard task.
You can find the colorful back cover for iphone 5cat witrigs.com.
这个答案有帮助吗?
得分 1
1条评论:
once you take apart the iphone to replace the back is there any new part besides the new back housing? any new adhesive you will need?
完成的
添加一条评论
Here's a site I found that sells the rear casings in every color:
http://www.etradesupply.com/apple/iphone...
However my problem is that I wish there were some sort of documentation on this. Well, time to watch the teardown 3 times through...
这个答案有帮助吗?
得分 0
添加一条评论
Yes the screen needs removed and the whole inside of the phone needs striped out and rebuilt in the new frame
这个答案有帮助吗?
得分 0
1条评论:
are there any videos to watch to help you step by step to change the back casing on the 5c?
完成的
添加一条评论
Can i go to the mall for changing my iphone 5c backcolor
这个答案有帮助吗?
得分 0
1条评论:
this is a site to help you fix your own device. if you want to ask the mall guy then you need to go to the mall and ask him? try googling which phone repair people are near you or what services they provide...otherwise check out the guide on how to do it yourself (the accepted answer) and purchase the part to do the change
完成的
添加一条评论
添加你的答案
Elouen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 127,095
