跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
PS3 won't accept a hard drive?
I've tried 5-6 hard drives. It will load up through the menu where it wants to reformat it but regardless of what HD I put in it, it doesn't accept it. I've tried so many PS3 and non ps3 hard drives and I'm at a lack of understanding as to why it wouldn't.
It's like it doesn't want to register it. Any solution to this because it has no warranty?
Model is CECHH01
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
did you try one of those steps?
maybe one of them helps
这个答案有帮助吗?
得分 1
7条评论:
markus, you can do better than that limp link ;-)
完成的
richard,
you're right - but there are many possible ways to get this done
ok - one trick could be to install windows on the hdd and then put it into the ps3 to format it.
another one is to put it in a larger model and format it there.
next one was formatting it with formatting tools
but i think that there are a few mor infos needed before a possible solution could be found.
what exactly happens when you try to format it in the ps3 ?
does the ps3 the hdd find at all ?
完成的
Thanks for the clarification +
完成的
Well yes.. I've tried quite a few drives and even reformatted 2 on the computer following instructions on how to do so.
When I put it in, it says you need to reformat this drive and then goes through 2 more pages and stops completely. It finds the drive, recognizes it needs to be reformatted but it's like it can't reformat it. Any ideas?
完成的
What hdd did you use? (speed/size). do you try to make a full format or a quick format?
完成的
显示更多的2条评论
添加一条评论
Try formatting the hard disk in format that PS3 supports
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim Kay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 6,492
