跳转到主内容
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is called the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
My controller won't connect
Could you help? I've done as you've said about holding power button and I've got the screen where it says connect controller. My problem that my controller won't connect, I'm using the cable from remote to ps3 but the red lights flash on controller and it goes off. Also I've tried restarting the controller but still the same..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Hi Carl Stock!
Do you try with another controller?
The symptoms are like your battery (inside of the controller) isn't ok or the USB connector on the controller is damaged or... your controller is broken ):
Regards.
这个答案有帮助吗?
得分 1
1条评论:
I charged them on a working system and they actually when I go to the other room and try to connect with the super slim model they turn on the older model and connect with it from another room
完成的
添加一条评论
Use the 'new' usb cable :)
这个答案有帮助吗?
得分 0
1条评论:
I have 5 usb cables , even with it connect to the system it will not pick them up it turns my earlier model on in another room
完成的
添加一条评论
添加你的答案
carl stock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 2,206
