跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3786 个问题 查看全部
问题已关闭
Would you recommend me fixing or trashing my old MacBook?
Hi!
I am a norwegian girl who just found this site. I have an old macbook with broken battery, it won`t charge. I have never fixed my own technical stuff...
Should I try to fix my mac? It is a macbook from 2008, so the battery should be easy to fix. But it could do with som more hard drive space and RAM, and the fan could possibly be changed to.. and then it is the crackes in the plastic case.. If I am to fix the machine, I would like to fix it so I can use it some more years..
Is it adviceble for me to try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
MStyx, lets start with properly identifying your computer. What are the last three digits of your serial number? This will help us to find the proper manuals and parts that might be needed for your computer. After that, success will depend on your technical abilities and on how much you want to spend. Just remember, ifixit and the people in this section here will be more than willing to help you with this.
完成的
THere's a lot of life left in that box, if you're not too demanding. If you can read and follow directions you can be a DIYer. Oldturkey is right the first thing is to identify your particular machine so you can calculate costs.
完成的
添加一条评论
1个答案
The problems you mentioned are probably pretty cheap to fix. Get your parts from eBay.... Maybe 30$ for a battery, $30 for some ram, and $3 for a fan?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
