跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Bad pin on digitizer conector - iPhone 5 logic board
I have an iPhone 5 that got wet. The screen would only show a very faint image and there was no touch response from the digitizer.
I replaced the LCD/Digitizer but while I was doing so I noticed one bad pin on the logic board where the digitizer connects. My screen now lights up and looks like new, but I have no touch response.
What now, look for a new logic board? I don't think I can fix the bad pin on the logic board for the digitizer connector.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
You probably couldn't fix it yourself, but the connector socket could be replaced with precision micro soldering. And it would likely be cheaper than a new board.
However, since there may be other things wrong with it, you may want to just think about describing it as it is and selling for parts on eBay.
Feel free to contact me if you need help finding someone to look at your board.
Jessa
这个答案有帮助吗?
得分 0
添加一条评论
My friend's iPhone 5s has a similar issue: Water damage, and even though the screen works, it reacts to no touch input.
I had already installed a new front display to no avail. I could not see any damage to the connector sockets either. I then removed the logic board, and then removed the tape around the display connectors. Under there I could see a lot of residue, possibly still causing shortcuts. I have then cleaned the board with 99% isoprop alcohol as described here:
Electronics Water Damage
But that didn't help, either. Still, the touch input is dead.
I wonder if some of the electronics got fried on the board. The digitzer uses high voltage, right? I guess that (dirty) water would more likely cause a shortcut in such a case, correct? In this case, is there a way to replace those parts, likely a kind of power inverter? Or get them professionally replaced?
这个答案有帮助吗?
得分 0
1条评论:
No touch combined with visible corrosion at the digitizer connector---that's a great candidate for reflowing that connector to solve.
完成的
添加一条评论
Just buy donor phone for new logic board
Update (01/04/2019)
I can transfer all your data to new logic board
这个答案有帮助吗?
得分 0
1条评论:
I had smiliar ptoblem with my iphone 5c
完成的
添加一条评论
添加你的答案
needDrivers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 3,865
