跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Reinstalling the MacBook top case
I need help aligning the clips over the super-drive to install the top case again. I recently cleaned the heatsink and fan, and cant seem to get the top case perfectly attached over the super-drive. It has a very large bulge over it.
Thanks!
P.S: I also redid the thermal paste with Arctic Silver Ceramique, and the idle tempatures went down on the CPU. However, the Chipset seems 1 to 2 degrees higher. Could someone please state their idle temps on their Late 2007 MacBook?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Have you got all the plastic clips over the superdrive in place and the right way round?
完成的
What is the correct way? Away from the outside of the mac, or pushed up on the side?
完成的
添加一条评论
1个答案
已选择的解决方案
The open side points into the machine. If you need a picture you can mail me: info@re-mac.de
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I see they must be open and not locked!
完成的
添加一条评论
添加你的答案
Zenitar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 5,074
