跳转到主内容
MacBook Pro带有15寸屏幕的型号
8262 个问题 查看全部
Audio-Out-Jack broken? Sound on left channel much lower.
Hello.
My computer: MacBook Pro 15", Mid 2010 (MacBookPro6,2)
If I plug external speakers in the audio-out-jack the sound is much lower on the left channel than on the right channel.
I already tried to solve the problem by...
- using other plugs / speakers / amplifiers
- blowing into the audio jack and gently moving the plug
... but nothing helped.
I therefore think, that the problem can only be that the jack itself is broken or that the audio software is broken? If the jack is broken, where do I get a replacement and how can I install it?
Thank you for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
You can not replace the jack - soldering logic boards requires special tools, solder and lots and lots of experience (it's easy to destroy logic boards with too much heat). If you've already checked and adjusted your System Preferences->Sound: Output Balance you could try a USB audio adapter.
USB audio is separate from analog audio, so if the problem is the jack this would alleviate that very easily.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Leon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 547
