跳转到主内容
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 个问题 查看全部
White Screen of Death and Graphics Problems - Solution
i've received a iPod Nano 1g today.
the device had a huge problem - the screen was distorted when i switched to another menu entry and when i woke it up from sleep mode the wsod was there.
since updating,resoring and resetting led to nothing i installed rockbox on the nano.
and that was it - the nano works great - no more wsod, no graphic distortions or anything else.
so i can only recommend this modification to save the 1st gen. nano from the recycle bin!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
i've played around with it a little more and seen a "problem".
if i select a dark theme - it sometimes has a slight blue flickering in the background - but the text's and everything is fully readable (not comparable with the original firmware issues where the screen was most of the time not readable or only white
完成的
添加一条评论
1个答案
已选择的解决方案
since i didn't find an answer to that problem here on ifixit, i postet it to share this with you all
这个答案有帮助吗?
得分 1
2条评论:
thanks richard - i've missed to link the page
完成的
添加一条评论
添加你的答案
markus weiher 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 10
总计 5,964
