跳转到主内容
Which Philips screws on left edge of keyboard area?
In step 28 of the ibook g4 Logic Board Replacement guide, the accompanying image shows which 3 screws need to be removed.
The problem is, those top & bottom left screws are different sizes than the bottom right one. What size screwdriver do I need for them?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Unless they have been replaced with something different, those screws should just be basic phillips screws...any smallish phillips-head screwdriver should do it. I don't know the technical size of the screws, and it really shouldn't matter so much. If they are problematic, I sometimes use a slightly larger phillips, which can give you a better grip.
If you've gotten to step 28, you should already have a screwdriver capable of dealing with those screws, so I get the idea from your question that there's something more to it than that...are they torx screws, or possibly are they stripped?
这个答案有帮助吗?
得分 1
1条评论:
Thanks. They're neither torx nor stripped; they are standard philips head, but I think they're size 00 as none of my screwdrivers (0,1,0-2) quite fit them. When you get down to the tiny sizes, it seems that exactitude of fit matters more and more.
完成的
添加一条评论
Small Phillips-head screwdriver.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jimryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,352
