跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Backlight doesn't work after LCD replacement.
I had a cracked LCD screen. Prior to disconnecting the LCD cables the backlight worked fine. I replaced the screen but since then the backlight doesn't work. I confirmed the backlight cable and LVDS cable are securely attached. What are the possible causes?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Did u get this fixed ??
完成的
添加一条评论
2个答案
已选择的解决方案
Blown fuse/controller for the backlight. This is not a DIY repair unless you work with electronic component replacement on a regular basis. Logic board soldering requires special tools, solder & lots and lots of practice.
Follow the tag at right for more information.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
3条评论:
Is there a way to confirm this visually before taking it in?
完成的
Kimberly, if you have a multimeter you could check the fuse for continuity.
完成的
Where is the fuse?? Location
完成的
添加一条评论
Check your backlight cable ... I installed mine the way the cable was positioned and best I got was black screen with faint apple symbol .....
But turns out I had it in backwards ... Was very awkward to flip cable and install bit that was it , try that just for !@#$% and giggles
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kimberly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 405
