跳转到主内容
Screen black, DVI output good, see desktop with flashlight
I'm looking for suggestions regarding these symptoms.
1. Screen flashes for less than a second at boot up.
2. Boot sequence finishes and all is well. Keyboard lights up, caps lock light works, function keys work.
3. Flashlight shown through logo shows desktop and working cursor.
4. Hooked up DVI to external monitor and it works fine. I can screen share and use the Macbook as well.
What needs replacing? LCD inverter? LCD cable? LCD?
I'll buy whatever it needs, but don't want to go down the rabbit hole. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
What are the last three digits of your computers serial number. This will assist us in finding the exact match for your specs.
完成的
MacBook Pro 2,2: 2.33Ghz: Last 3 of serial: W0H
Thanks
完成的
添加一条评论
1个答案
已选择的解决方案
Your problem is most likely the inverter or the inverter cable, I would replace both.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the response Dan. I started searching for the inverter and noticed various web sites were referencing part number 612-0038-A and 612-0035-A as interchangeable for the A1211 MacBook Pro.
I haven't opened the LCD to check the part number yet. Do you know which one is correct? Thanks again.
完成的
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 327
