跳转到主内容
加入维修社区 - 创建账户
1999年7月苹果发布消费级笔记本电脑产品 iBook G3。
No RAM = No display?
Hello there iFixit community.
I recently bought a broken iBook G3 off of eBay and the seller claimed the iBook would play the classic start up chime and have no display.
Now I thought the iBook had the well known soldering issue, or had a bad LCD monitor, however when I took it apart, I discovered the iBook had no RAM.
Now this brings on the main question, because my "new" iBook has no RAM, is this what is stopping the display from appearing, or should I still attempt to find and solder the graphics chip?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Actually, there is no such thing as an iBook with no RAM, because all iBook G3s have at least 64MB permanently embedded in the logic board. Most likely you're just dealing with the typical iBook G3 video defect, which at this point isn't worth putting effort into (unless you're a hobbyist messing around for the fun of it).
这个答案有帮助吗?
得分 2
3条评论:
You're right - been so long I forgot about that.
完成的
Thank you for your answer.
I'll try to fix the screen, as I purchase quite a few busted computers off eBay to repair and this is my first iBook.
Once again thanks your answer.
完成的
If the laptop has the video defect, replacing the screen will not help -- the issue is the video chip becoming disconnected from the logic board. The only way to permanent fix this is to remove and re-affix the chip, which requires professional tools and experience, and is just not worth the cost or effort considering you're dealing with a laptop that has a value of $50 when fully working.
完成的
添加一条评论
添加你的答案
Nathan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 143
