Is there any repair for netgear wireless router?
router is not receving power from the cable. can the router be repaired? if yes how much does it cost????????
awaiting your reply...
To start with have you tried a second power transformer. If you look on the bottom of the unit you should find a diagram which will tell you the units power requirements. I would suspect it needs 12volts 1Amp and the plugs inner core is the positive contact. Please double check this and locate the needed unit. What happens when you plug in the other unit and you press the power button? Does any LED's light up at all?
这个答案有帮助吗?
Any luck getting a new power transformer?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 944
8条评论
please anyone do suggest me to solve this problem
由 vamsi krishna 完成的
Can you give us the products name & model number of your unit.
由 Dan 完成的
NETGEAR Wireless-N150 Router WGR614
由 vamsi krishna 完成的
vamsi krishna, "not receving power from the cable" are you saying that the router does not turn on? Receives power from what cable?
由 oldturkey03 完成的
Here's a good resource Netgear N150 Router documentation
由 Dan 完成的
显示更多的3条评论
