跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
291 个问题 查看全部
disassembly guide for iMac Intel 21.5"
Have you produced a guide for the disassembly for this model or, if not, which guide would be most similar?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Thank you for your interest! We do not have a guide yet for this machine.
We have a teardown for the 27" iMac, which is relatively similar, but no repair guide for either yet (as it is a very new machine). Check back often, as we are constantly adding new content!
In terms of similarity, the new iMacs are fairly unique inside, so nothing directly compares yet.
I hope this helps!
这个答案有帮助吗?
得分 2
2条评论:
Thanks, that is an excellent teardown article. Just one part that still puzzles me. Where should the two suction cups be placed to 'safely' remove the front panel? There is a note that says that the panel rotates up from the bottom side and yet the photos show them placed at diagonal corners. If it rotates from the bottom, shouldn't the suction be placed at the top corners? Thanks.
完成的
This may be the note you are already referring to, but this describes with more detail how to safely remove the glass (it says to put the suction cups near the top edge).
完成的
添加一条评论
I couldn't find one on 21.5 but here is the teardown for 20". You can view it and compare to your unit and see if it compares. Ralph
这个答案有帮助吗?
得分 1
添加一条评论
I found a nice one here iMac Intel 21.5" EMC 2308 Logic Board Replacement
这个答案有帮助吗?
得分 1
1条评论:
@Jeff Smith, hopefully the OP got it fixed within the last 4 years ;-)
完成的
添加一条评论
添加你的答案
dave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 42,240
