跳转到主内容
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
114 个问题 查看全部
问题已关闭
What can be wrong? 06 equinox wont start.
just got my 06 equinox. Guy i got it from said the starter was probably going bad. it started after it hesitated a bit and sometimes it started right up at the second attempt. now a few weeks later, car is not starting at all. 1st and 2nd try with jumper cables worked to start the car. and now it wont start at all even when jumper cables are connected. any help is appreciated, its my wifes daily to work and its just sitting for now, she has to take the bus :/
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It might be the starter. Have your wife try to start it by turning the key while you simultaneously hit the starter with a hammer. Make sure all breaks are engaged and try to be safe about it. THe starter is attached to the engine block.
Starters have an internal piece which makes contact when the key is turned. Over time they wear out. Also, check your grounds, everything should be making good contact, not just at the battery, but also on the body/frame. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,727
