跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
Why is the bottom left corner so warm? (wifi issue?)
I've noticed the bottom left corner (on the back) to be slightly warm under moderate usage, but recently it seems to be warmer than usual. Wifi strength is really low (1 bar) even when right beside wifi router. I don't have any wifi security enabled on the router. I restored through iTunes and still same problem. Nothing internal was changed between when it was fine and now nor was anything changed on the wifi router. Everything else works without issue.
Parts I've replaced a few months ago: battery, back cover, digitizer, lcd, headphone jack.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I've got the same problem with the hot corner. For me, it gets the most hot when plugged into a power source, especially while the screen is on. For instance, if I'm playing a game with the power plugged in, the corner is quite hot. The heat covers about the area of a nickel, and is strong enough that I can feel it through the top of the iPod, too.
Any ideas at all? It's kind of a hard topic to accurately search.
完成的
same here Tim Valenta i find that it happens when plugged in also and the heat managed to damage my ipod which apple had to replace under warranty.
完成的
添加一条评论
2个答案
已选择的解决方案
well, not a wire per say, but skippy has the right idea.
maybe there's a short somewhere along the board.
when you have free time you should open up the device, disconnect the battery and give the unit an iso-propyl alcohol bath (use a soft bristle brush)
Rinse with iso when finished and let dry thoroughly, then when done let it dry some more :)
re-solder and let me know your results.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
There could be a short causing problems with the wifi and heating up the back. You should make sure that there are no stray wires touching the back.
这个答案有帮助吗?
得分 1
1条评论:
there are no wires inside of the iPod touch
完成的
添加一条评论
添加你的答案
SYN1ST3R 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 5,584
