Why is the bottom left corner so warm? (wifi issue?)
I've noticed the bottom left corner (on the back) to be slightly warm under moderate usage, but recently it seems to be warmer than usual. Wifi strength is really low (1 bar) even when right beside wifi router. I don't have any wifi security enabled on the router. I restored through iTunes and still same problem. Nothing internal was changed between when it was fine and now nor was anything changed on the wifi router. Everything else works without issue.
Parts I've replaced a few months ago: battery, back cover, digitizer, lcd, headphone jack.
2条评论
I've got the same problem with the hot corner. For me, it gets the most hot when plugged into a power source, especially while the screen is on. For instance, if I'm playing a game with the power plugged in, the corner is quite hot. The heat covers about the area of a nickel, and is strong enough that I can feel it through the top of the iPod, too.
Any ideas at all? It's kind of a hard topic to accurately search.
由 Tim Valenta 完成的
same here Tim Valenta i find that it happens when plugged in also and the heat managed to damage my ipod which apple had to replace under warranty.
由 Dale Hughes 完成的
