跳转到主内容
Can the computer itself make a HDD go bad?
Craigslist had an immaculate iBook G4 in my area for short money and I was able to score it for my kids to use. We use it to play music and movies and games. It had a 30G HDD but everything started to act up. Programs would just close during use, and then all I could get was the startup sound, a grey screen and the Apple with the spinning wheel.
So I decided to replace the HDD with one (250G) from my old iBook G4 that worked, however the logic board was failing me.
Everything was fine for the first 3 times I used the computer, then it started to act up in the same way it did when I had the 30G HDD in there. I reset the PRAM and the PMU already.
What else do I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
+1 Great question! It's so helpful to know what steps to diagnose you've already tried.
完成的
添加一条评论
1个答案
已选择的解决方案
Definitely not an HD issue then, you should run some diagnostics, such as the AHT, also take a look at the RAM.
这个答案有帮助吗?
得分 2
3条评论:
Thanks, I R&R'd the RAM and it works again.
完成的
That's usually my second thing to check, 1) HD, 2) RAM
完成的
+ Ralph
完成的
添加一条评论
添加你的答案
040304 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 995
