跳转到主内容
PlayStation 3 Slim是Sony Computer Entertainment生产的PS3视频游戏机的第二版。 它于2009年9月1日发布。
465 个问题 查看全部
问题已关闭
Blu Ray ribbon on 160gb ps3
I've used the repair guide for replacing the blu ray drive on a ps3 slim and its been great up to re-assembly. The guide is for a 120gb model which has a different disk drive layout.
My model (160gb) has the main ribbon directly underneath the drive (instead of with the rest of the leads on the side) and Im completely stumped over how to re-attach it, due to its short length the drive is too close to the rest of the unit for me to get my hands in or see what im doing.
Does anyone have any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I had the same problem. When you pull out the ribbon gently it will give you more slack.
This is possible because the blu-ray carrier slides a bit on its guides. Don't pull to hard.
This will give you more room to attach it to the conector on the mainboard.
If you can't give it more slack then open the cover of the blu-ray player and place de blu-ray carrier in the middle of the two guides. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Lift up the front a little or the back, use a flat head to push up the both sides of the clamp on motherboard on the back side of the laser Lens ribbon at the socket, repeat backwards to replace.. Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
Use a pair of hemostats
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 948
