跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
cooling impeller makes too noise...
Hi
I've follow your instructions and changed the HD to my mac mini...everything was perfect...but now the cooling impeller give me a lot of noise....It always runs and take out a lot of air...It never stops...
What did I do wrong ?
Thanks in advance..
Fabrizio
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Well it could be because the temperature sensor was disconnected from something (maybe the HDD). When I replaced my HDD with an SSD (Which had no aux port for temperature) my computer reports my HDD to be 128 degrees Celsius. To check if its the temperature thats making the fans run at 100%, you should download iStat Pro or iStat Mini
iStat Pro
iStat Nano
这个答案有帮助吗?
得分 1
1条评论:
good +
完成的
添加一条评论
添加你的答案
Fabrizio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,163
