How do I wash my Patagonia sweater/jacket?
这是一个好问题吗?
Garments that keep you warm on brisk days and dry on wet days. Repair difficulty ranges from simple tear patching to more complicated baffle repair.
Most down insulated garments can be machine washed in cold water, and then tumble dried on low. Add a couple of tennis balls to fluff up the garment. Be sure to check the label on your garment before you wash or dry it, as it may have different instructions. You can also check out Patagonia's care guide for down insulation. See the Patagonia Product Care Guide.
Best way to wash down garments is to wash normally (cold water, medium or delicate cycle). Then the trick here is to AIR DRY!!!! Lay that jacket out for 24 hours, THEN fluff it in the dryer, you won't even need heat.
When you let the jacket air dry, the down clumps much less than if you dry it immediately. Less fluffing in the dryer means less wear and tear on your jacket and a longer, happier relationship.
过去的24小时: 13
过去的7天: 81
过去的30天: 447
总计 46,452
