跳转到主内容
加入维修社区 - 创建账户
Keyboard wasn't working intermittently. Now MBP won't boot
Hi all,
First of all thanks for these very helpful guides. Here is my problem.
I have received a MBP on which the keyboard and trackpad intermittently stopped working. I knew it was a hardware problem as it happened straight at boot time.
I first suspected a loose connection, so I did steps 1 to 14 of this guide :
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Keyboard Replacement
And then reversed it. That way I had removed connections and put them back. Still no success.
I googled a bit more and found this :
http://lbarclay.wordpress.com/2009/01/29...
I tried it, and it worked perfectly. I just used electric tape to create a bump over the ribbon. When the battery went in place, everything worked perfect... For 2 hours.
I then wanted to check if the tape wasn't overheating, I removed the battery slot while the power was plugged. Computer powered off, and then wouldn't turn back on.
I went on and redid all the previous disassembly/reassembly with no success...
Any idea where this could come from??
Thanks a lot,
Simo
Update
A few more hints, dunno if they are of any use :
- Tried booting WITH and WITHOUT battery in : Nothing
- Tried booting WITH and WITHOUT the power adapter : Nothing
- Tried moving/pressing the orange ribbon while trying to boot : Nothing
- Tried shorting the PWR solder dots : Nothing
- I left the computer as it was (powered off) with the battery in and not plugged to the power for a few hours: The battery went from fully charged to fully discharged.
- After plugging in the adapter, the battery doesn't seem to be charging after 45mn (according to the owner, when her battery used to be fully discharged, it would always take 10 to 20 mn before she could power the MBP back up. Not using the original power adapter)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Note that NOTHING happens when pressing the power button. No fans, no lights. Nothing.
- Battery has 4 lights on
- Power supply shows green light when plugged in
完成的
添加一条评论
3个答案
已选择的解决方案
The internal Powerbutton is located left to the right fan (can't describe that better). Just two solderdots marked "PWR". Use a magnifier, that helps. Shorten the dots with a screwdriver or similar. If it powers on - hey presto, you need a new topcase. ;-)
这个答案有帮助吗?
得分 1
2条评论:
Sorry that nothing helped. The only thing you could try at this stage is removing the backup battery for a minute. It sits underneath the optical drive and is connected to the logicboard via a small 2 pin connector just north of the OD.
完成的
For info, I accepted this answer because it did answer my question about how to short the PWR, but it didn't fix the problem. Thanks anyway for your help :)
完成的
添加一条评论
Very nice question, + vote. Try starting up with the battery removed. If that works you may need to rewire and reroute the wires.
这个答案有帮助吗?
得分 0
1条评论:
I had tried it, unfortunately with no luck.
I have read that there were some "PWR" connectors that could be shorted to try and power it without the uppercase, but can't find them. Any idea where they are?
完成的
添加一条评论
I finally found these PWR solderdots. They weren't anywhere that I read about. They actually were to the right of the memory slots :
I tried to short them with power cable only, with battery only, and with both. None of it worked. No fan movement, no light, nothing :(
Any suggestion?
这个答案有帮助吗?
得分 0
1条评论:
Sorry to have added this as a reply instead of comment, it was the only way I found to attach a picture.
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 1,009
