跳转到主内容
东芝所制造的笔记本电脑。
1272 个问题 查看全部
问题已关闭
Why is it my usb drives not working properly?
Ok i have a wired x-box 360 controller i use for games such as Skyrim and every time i seem to move or accidentally tap the usb drive connected to the X-box 360 controller it just stops working. its not the controller i have tested the issue with a different controller and same issues occur. the only solution i have found to work (temporally) is to turn off my computer and then back on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
do you have those issues with other USB components? It is possible that you have some physical damage to the USB port.
完成的
添加一条评论
1个答案
go to control panel and use the utility system, and "restore system" and put the last days that you know was worling good. However if the problem persist, you must update your driver can be corrupted.
downlod from your supplier computer website and donwload for free.
God bless you
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 109
