跳转到主内容
问题已关闭
Upgrade to a 1TB 7200 RPM SATA III 32MB?
Can I upgrade this computer with a HGST Travelstar 7K1000 2.5-Inch 1TB 7200 RPM SATA III 32MB Cache Internal Hard Drive (0J22423)?
I have the 2.7 GHz model.
Would this affect my battery performance?
1.0TB HGST Travelstar™ 7K1000 Specifications:
Specifications:
Form Factor :2.5″ HDD
Interface: SATA 6.0Gb/s (3Gb/s firmware enabled4)
Capacity1: 1000GB
Formatted Capacity2 :930GiB
Rotational Speed :7,200 RPM
Cache / Data Buffer :32MB
Manufacturer Model Number :HTS721010A9E630
Physical
Height (max): 9.5mm (0.370″)
Width (max): 69.85mm (2.750″)
Length (max): 100.35mm (3.951″)
Weight (typical): 95g (0.209 lbs.)
Bytes per Sector: 512
Areal Density: 676Gb/in2
Reliability
Contact Start-Stops: 600,000
Warranty: 3 Year HGST Warranty (for replacement with standard 6Gb/s firmware). 3 Year OWC Warranty (for replacement with 3Gb/s firmware enabled)
Performance
Transfer Rate (Max): 600MB/s
Track-to-track Seek: 1.0ms
Average Seek Time: 13.0ms
Average Latency: 4.2ms
Power
Maximum Start Current, DC: 5.5 Watts
Seek Power: 2.1 Watts
Read Power: 1.8 Watts
Write Power: 1.8 Watts
Idle Mode: 1.7 Watts
Idle Mode, Active: 1.0 Watts
Idle Mode, Low Power: 0.8 Watts
Standby Mode: 0.2 Watts
Sleep Mode: 0.1 Watts
If not, then which HDD would you recomend?
Thank for your help!
Enrique L.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes it will fit and work - might shorten your battery life though.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,233
