跳转到主内容
Do I really need to replace my SSD?
About three months ago my 11" macbook air fell from the table and landed on it's front left corner (if it's before you as if you want to open it). There was some minor observable damage (a small dent). But the laptop worked just fine for about 3 months. And yesterday I tried to turn it on and got the "Mac OS utilities" screen. Disk utility tells about the "invalid B-tree node size" and I can't do anything about it (fsck, fsck_hfs etc. do not help). Also I can't turn it on in the safe mode. So I gave my laptop to one of the repair companies. They tell me that I need to replace SSD and that all info is 100% lost. But the SSD in macbook air is on the opposite side from the one that it fell on. And it worked fine for 3 months or even more. So, is it possible that what they tell me is true, or do they just want my money?
P.S. And also, I live in the country where there are no official Apple service centers or something like that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try contacting Apple Support here: http://support.apple.com/kb/HE57
This may fall under the "MacBook Air Flash Storage Drive Replacement Program". Go here for more information: http://www.apple.com/support/macbookair-...
这个答案有帮助吗?
得分 2
添加一条评论
There are defective SSDs on the market, they will fail after some time. SSDs usually do not get damaged by shock. Contact apple and they will replace your SSD for free. Since this is an official replacement program, apple may cover shipping costs. Ask them
这个答案有帮助吗?
得分 1
2条评论:
Will they accept it with visible signs of external damage?
完成的
They will unless they believe the malfunction is caused by physical abuse. In this case it can go either way, depending on how they see it. It seems to be software/SSD firmware error to me. There is no mechanical parts that can be damaged by mechanical shock in a SSD. These suckers are used in aircraft FDRs, if they can survive an airplane crash, it's highly unlikely a drop can damage your SSD. "invalid binary tree size" is a file system error, there are some software ways to fix this. Try them. If everything fails, go find apple for help
完成的
添加一条评论
添加你的答案
Rammi Dgham 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 303
